Spark Plugs
Old Sep 26, 2005 | 09:32 PM
97formulakid's Avatar
Spark Plugs
I have some NGK TR6's in my car right now that are still in there from when I had my nitrous on the car. I have some brand new platinum stock replacements sitting in my garage. I bought them before the nitrous and then just put the NGK's in. My question is, should I put the Platinum stock plugs back in or is it ok to run the NGK's which are still gapped at .035???
Old Sep 26, 2005 | 09:38 PM
blind527's Avatar
Re: Spark Plugs
I can't help you but I had the same mods you did, ran a 13.8. Got LT's and ORY I got a 13.4.
Old Sep 26, 2005 | 10:23 PM
OBE1 95Z28's Avatar
Re: Spark Plugs
You can keep running the TR6's. Since they're non-platinum, they'll only last around 30K miles though.
Old Sep 26, 2005 | 10:40 PM
darkangel95's Avatar
Re: Spark Plugs
I run TR6's in my N/A mild bolt-on car and it runs perfectly fine. I would just stay with them as long as you don't mind changing your plugs a little more often.
Old Sep 26, 2005 | 11:51 PM
2000GTP's Avatar
Re: Spark Plugs
You should be okay, and as stated above, you may requier more regular change intervals. I read an article though where some guys ran TR-6 plugs in a mild bolt-on naturally aspirated LS1 and picked up a few hp at the rear wheels, so take that for what it is worth.
Old Sep 27, 2005 | 06:24 PM
Re: Spark Plugs
thanks guys. if there wont be a difference ill just leave those plugs in there. no use in changing htem out if i dont have to.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
