Spark plugs!?
Old Sep 20, 2003 | 10:58 PM
NewbieWar's Avatar
Question Spark plugs!?
how the hell are u supposed to change the spark plugs?
when under the car i can only see 1 of them, i can see the wires fine, and from on top i cant see any of em
what is the easiest way to replace them?
Old Sep 21, 2003 | 01:19 AM
chasmanz28's Avatar
Re: Spark plugs!?
Here's the best method (without Y-pipe removal) found so far:
PLUG
ACCESS
TOOLS REQUIRED
COMMENTS
Top
Socket w/ Swivel
Easy
Top
Socket w/ Swivel
Easy
Bot
Socket w/ Swivel
Slightly tricky
Bot
Socket w/ Swivel
Watch out for O2 sensor
Top
Socket w/ Open End
AC & Exhaust AIR Tubes make it NASTY
Top
Socket w/ Swivel
Completely blind on this one
Bot
Socket w/ Swivel
Difficult to reach, but doable
Bot
Socket w/ Swivel
Skinny arms are a MUST
NOTES:
Be sure to replace the heat shield covers on plugs 6, 7, and 8.
If you're changing the wires, be sure to route the #7 wire through the factory heat shield that runs between the exhaust manifold and the block. If it makes contact with the manifold, it's going to burn right through.
Use anti-seize compound on new plugs. The factory didn't which made removal that much more difficult.
You may want to do the easiest plugs first, (saving #2 for last) to give yourself a sense of accomplishment and to boost your self-confidence.
Old Sep 21, 2003 | 07:05 AM
BlueCamaroZ28's Avatar
Cool
Well, it is a different story with long tube headers like my Edelbrok's. I don't know how you reached #2 with A/C compressor blocking the veiw.
The right bank was easier though. The left bank, made me unbolt the left header but that was needed anyway since I was replacing a leaking gasket.
Old Sep 21, 2003 | 10:38 AM
NewbieWar's Avatar
better to do from above?
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
