Spark plug installation/OTVC tips
Old Jan 23, 2008 | 08:09 PM
ssbowtie1's Avatar
I just realized I don't have any anti-seize for my spark plugs. Is it ok to install plugs without anti-seize or will I encounter major problems when I try to remove them later. They're NGK irridiums, so I don't plan on removing them for a while.
Also, does anyone have any special tips for installing taylor OTVC wires on a car with emissions hookups. I'm going to tackle it tonight so any tips are appreciated.
Old Jan 23, 2008 | 08:19 PM
droptop z's Avatar
I always use anti seize on my spark plugs, it'll only cost you a few bucks. I used this guide to install my OTVC wire set http://ken.lowrance.com/Projects/OVC...OVCInstall.htm
Old Jan 23, 2008 | 08:21 PM
96ZCamaro's Avatar
I have installed spark plugs on my car without antiseize no problem. But yet I take them out a lot more then you average person. If you plan on keeping them in there for a while I would go ahead and get some antiseize.
Old Jan 23, 2008 | 08:24 PM
ssbowtie1's Avatar
If it was up to me I'd get some...but my car isn't running right now and I don't have a way to get to the auto parts store for another few days. Basically the plug install will keep me from making much more progress on the car until I get to an auto parts store. I think I'm just going to install them dry.
Old Jan 23, 2008 | 08:31 PM
shock6906's Avatar
Do you not have a friend that you can get a ride from? Shoot, you can get some at AutoZone for a dollar or less. See if a buddy will just pick some up for you. I'd do it for my friends.
Old Jan 23, 2008 | 09:34 PM
94zgreenmachine's Avatar
Anti-seize, your call. If you don't they can and will get stuck stripping the plug holes. Then you'll be pulling heads off to have a helicoil installed.Something so simple can cost big dollars down the road.
Old Jan 23, 2008 | 10:13 PM
Green96Z's Avatar
+1. Anti-sieze means just what the title says. It keeps the plugs from siezing inside the heads. Do yourself a favor and install them with anti-sieze.
Old Jan 23, 2008 | 11:11 PM
ssbowtie1's Avatar
Alright guys I'll just call it a night and try to get some anti-seize tomorrow.
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
racecarz28
Mar 30, 2015 09:55 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
