Spark plug and header tube problem
Old Sep 16, 2004 | 04:37 PM
cmking26's Avatar
The rear spark plug on drivers side is hitting the header primary tube. Cant get it to start. I dont want to unbolt header is there anyone who makes a short platinum plug that would work? Or any other ideas.
Old Sep 16, 2004 | 05:42 PM
cmking26's Avatar
Re: Spark plug and header tube problem
Anyone??? A shorter plug would be perfect if I can find one.
Old Sep 16, 2004 | 06:53 PM
Fuels94TA's Avatar
First is what type of headers, and plugs are you using?
Old Sep 16, 2004 | 07:07 PM
1 Nasty Bird's Avatar
Accel makes a shorty plug, dont knwo what # youd be looking for and they are NOT platinums. Expect to pay about 3-6 bux a plug i know theyre not cheap.
Old Sep 16, 2004 | 07:29 PM
godofdragons's Avatar
i have to unbolt my slp headers tochange the plugs. dont know what kind you have though
Old Sep 16, 2004 | 11:33 PM
cmking26's Avatar
Pacesetter shorties. I just need one plug can I get that short accel plug from Summit? And does it have to be platinum like the other 7 are? Bosch platinum are the other 7.
Old Sep 17, 2004 | 05:37 AM
If it was me id return the bosch platinums (totally a garbage plug for a v-8) and get 8 shorty plugs from summit or jegs. Performance will be noticably better and itll be easier whne you have to do plugs later.
Old Sep 17, 2004 | 09:14 AM
Fuels94TA's Avatar
Is there a reason your using plat. plugs? Your car will run just fine on a standard plug. Many board memebr do, the only draw back is you will change them more often. I wouldnt mix plugs just try to keep them all same.
Old Sep 17, 2004 | 12:59 PM
cmking26's Avatar
I ordered accel shorty plugs from Summit. Thanks for help
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
