spark plug gap suggestions
Old Feb 19, 2003 | 09:40 AM
pearl93Z's Avatar
I have a 93Z28 with 3:73 gears, hypertech 160 , hypertech chip, hooker lt's, tb bypass, morosso cai and I just bought NGK tr55 plugs, the guy at napa told me to gap them at .045, others have told me .050 and I just read a post from about a year ago on here from a 385lt1 or something like that that said stock heat range requires a gap of .060 So which do I use? Thanks for looking at this.
Old Feb 19, 2003 | 09:48 AM
Smoke T/A's Avatar
I would go with the stock reccomendation of .050 unless you are using a power adder or running higher compression. In that case I would reduce the gap to .035 IMO.
Joe
Old Feb 19, 2003 | 08:17 PM
my94blackz's Avatar
I just replaced my plugs with ngks and they came gapped at bout .55-.57. My old ones from the previous owner was gapped between .65-.73, i was like what was he thinking?
96cam4ro's Avatar
I thought they came pre-gapped??
Old Feb 19, 2003 | 08:22 PM
RamAir95TA's Avatar
They do come pre-gapped, but they might become mis-handled etc., during shipping. It doesn't hurt to check.
Old Feb 19, 2003 | 09:26 PM
Smoke T/A's Avatar
Well over time the plug gap increases. All the NGK Tr55's I have bought were gapped at .060 and above. The only ones that were gapped were the NGKTR6's at .035.
Old Feb 19, 2003 | 09:59 PM
Anderson's Avatar
How much of a diference can realy be felt form a gap of .050 and .060??
Just wondering how big or small of a diference that might be.
Old Feb 20, 2003 | 02:48 AM
Stealth Z's Avatar
Since the gap size has a direct affect on the spark plug's tip temperature and on the voltage necessary to ionise (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximises burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
In reality, computer controlled vehicles do such a good job of lighting off the air/fuel mixture (as evidenced by the ultra-low emissions), added ignition capacity would do little to burn more fuel since the stock configuration is doing such a good job. Older non-computer controlled vehicles or those that have been modified with higher compression or boosted (nitrous, turbo, supercharged) engines can certainly take advantage of a more powerful ignition system.
-NGK
Old Feb 20, 2003 | 02:59 AM
94Z & 96SS's Avatar
Your not going to feel a diff. between .50 and .60.
Old Feb 23, 2003 | 10:45 PM
synethics's Avatar
What should I gap my plugs at with my heads being milled down 10000ths over and some air induction mods, and headers.
Old Feb 23, 2003 | 10:49 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
My rapid fires came gapped at .45 but i changed them all to .50
Old Feb 23, 2003 | 11:37 PM
Don't ever assume what a plug's gap is. Check it and adjust if necessary, before you put it in your engine.
Old Feb 24, 2003 | 12:17 AM
Dr.Mudge's Avatar
If they were on the car for awhile, remember with age the gap will increase.
Old Feb 24, 2003 | 12:19 AM
Dr.Mudge's Avatar
So long as you have the voltage to jump the gap, the stock system will only put out so much, if we had coil on a plug I wonder how that might be different. Eventually the spark will be 'weak' and kill your coil prematurely.
Old Feb 24, 2003 | 12:21 AM
Originally posted by Dr.Mudge
... remember with age the gap will increase.
Same thing is happening with the synapses in my head.
