Spark plug gap...
Old May 27, 2004 | 04:32 AM
Myxtreme1's Avatar
Spark plug gap...
What is the gap supposed to be? I removed mine and they look like they might not all be the same. What problems could that cause and what is an easy way to clean them here at home?
Old May 27, 2004 | 04:44 AM
Andrew04ME's Avatar
Stock gap is .050
If your not sure they are all gapped the same, why not just go spend $20 and get new ones? If you would rather keep the ones you have, I've heard of people using wire brushes to clean plugs.
Old May 27, 2004 | 07:16 AM
n2ceptor's Avatar
I use a nail file emery board to clean.... And I confirm what Andrewo4me said .050.....
Old May 27, 2004 | 03:46 PM
Myxtreme1's Avatar
Where can you get the ac delco plugs for $20? And they are new, well about 7 months old. Thanks for the replies guys!
Old May 27, 2004 | 04:26 PM
BUBBA's Avatar
Always change your plugs when you have them out.
Always "check" the gaps, even on new plugs to ensure the correct gap. JMHO
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
