Spark plug diagnosis needed please.
Old Dec 9, 2003 | 06:00 PM
Larnach's Avatar
As the title says... this is running without a tune and open headers in cold weather. Maybe about 45 minutes of driving, #3 wasn't even tightened down. My fault.
http://www.siknor.com/Camaro031208NGKTR5501.jpg
http://www.siknor.com/Camaro031208NGKTR5502.jpg
Old Dec 9, 2003 | 06:20 PM
slopokrodrigez's Avatar
They look like they're fouled from being too rich. Assuming your air filter is ok, I would scan it to see what your O2's are doing. Check a few other things also. Like the output of the engine temperature sensor. If it is not showing the engine warming up, the PCm may think it's still cold and keep it in open loop. Remember the gage in the dash uses a different sensor than the PCM. This of course will richen the fuel input and may contribute to your rich condition.
Old Dec 9, 2003 | 06:24 PM
Larnach's Avatar
Thanks for the input. I believe it may be f'ing up because of running no exhaust on the car. The O2 sensors are about 2" from the outside air, could be throwing it off?
Old Dec 9, 2003 | 06:26 PM
Most definately. They will show way too much O2. Thus richen the mixture. And they are definately rich fouled.
Old Dec 9, 2003 | 06:32 PM
ChevyIron's Avatar
I second Sloporodrigez oppioun I have the same sitation open headers plugs fouled up and would barley run.Definetly get the rest of the exhaust on then you should be alright.
Old Dec 9, 2003 | 06:37 PM
Larnach's Avatar
Will do, I'm thinking about new O2 sensors, but I want to know if there is a way to test them or not before I drop $150.
Thanks again for the input.
Old Dec 9, 2003 | 06:52 PM
Only with scanning equipment. While they are warm in closed loop mode.
Old Dec 9, 2003 | 06:55 PM
Larnach's Avatar
Well I know they get warm, I left the key on for some reason one day and they warmed up quite a bit.
Old Dec 9, 2003 | 07:02 PM
Sorry I meant with the engine warmed up to operating temp.
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
94z28jbw
Sep 8, 2002 03:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
