Spark Jumping Out of my Coil Wire????
Old Feb 25, 2006 | 02:02 PM
94StockFormula's Avatar
I noticed my car start running worse 3 days ago. I looked down by the coil and saw blue light arcing out so i thought my coil was bad. I put a new coil in last night and a new coil wire. I then saw blue sparks arcing out of the middle of the wire and onto things by my engine like bolts and I could get it to arc to my screwdriver. I then tried 2 different new wires and then put an new msd coil on today thinking maybe there was a short in the coil.(Plus i wanted the msd coil anyway). I'm thinking either there is a ground problem or my optispark is bad making it easier for electricity to arc out of the actual wire then through the optispark?? Any help would be appreciated.
Old Feb 25, 2006 | 02:25 PM
Dave89IROC's Avatar
Re: Spark Jumping Out of my Coil Wire????
anything after the coil can do this, opti, plug wires or plugs
Old Feb 25, 2006 | 04:14 PM
blue's Avatar
I wouldn't put too much stock in the sparks unless you see one you know is out of the ordinary. I spent about an hour in the dark before with the engine running looking at various sparks and thinking one of them was the problem but it turned out to be burned plug wires.
I would say your theory on the opti causing the lower resistance path to be across the coil wire to something else instead of through the correct path would be possible but unlikely. I would change the wires and plugs before the opti.
Old Feb 25, 2006 | 09:26 PM
94Camaro_Z_28's Avatar
I agree....change the wires and plugs before the opti. I'd imagine a bad plug would be able to up the resistance enough to do it before something in the opti, plus, it's a hell of a lot cheaper to change them first.
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DougJ
Aug 29, 2002 12:51 AM
