sound like a bad starter?
Old Jul 18, 2006 | 03:24 PM
Chevycobb's Avatar
the past couple of weeks my car has been doing a slow crank before actually firing up. The slow cranking wouldn't be as slow on cold starts. Yesterday it took forever to crank but I was carefull to not turn it to much because I didn't want to fry the starter any more then it already may have been. When I would try to crank it, it seemed to draw a lot of power from everything else(gauges and radio would almost shut off) before starting...Like it needed a lot more power from the battery to turn faster. Now I get nothing but a single click when I try to start it, but all accessories and lights are staying on. New battery and new 140amp alternator. You think my starter is fried??
Old Jul 18, 2006 | 03:33 PM
93transam1234's Avatar
Re: sound like a bad starter?
I would first check the battery cables the cables going to the started.
I am pretty sure most auto parts stores will test the started for free (has to be off the car)
Old Jul 18, 2006 | 03:34 PM
also try a jump start first too, maybe you just left a light on or something
Old Jul 18, 2006 | 05:15 PM
1racerdude's Avatar
Yep
Old Jul 18, 2006 | 06:03 PM
Dennis93TA's Avatar
mine was just replaced because it was cranking slow and draining the **** out of my battery. mine also acted like the battery needed more juice. New one installed, cranks fine now.
Critter
Jul 7, 2015 08:33 PM
Jun 6, 2015 08:27 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
mattszm6
Dec 14, 2014 07:09 AM
