Somethings wrong with my a/c...
Old Aug 9, 2004 | 02:27 AM
SkillZ25's Avatar
Umm, i was just wondering if anybody knew why my AC is comming out of my defroster vents instead of the regular ones.
Old Aug 9, 2004 | 03:58 AM
skisax80's Avatar
Re: Somethings wrong with my a/c...
sounds like a switch problem.....have u ever had any work done on it?
Old Aug 9, 2004 | 04:01 AM
SkillZ25's Avatar
Nope, as a matter of fact when i test drove it 3 weeks ago it was fine but right when i bought it it changed. The car is in perfect shape and the guy took great care of it so i dont think he sabatoged it.
Old Aug 9, 2004 | 04:05 AM
skisax80's Avatar
hmm could just be a short then, critters have a way of doing things like that.. thats the only thing i can come up with, is that there is a short in a wire... thats the only thing that i can see would cause u to put the switch in one spot and it control another...
Old Aug 9, 2004 | 04:10 AM
SkillZ25's Avatar
Huh...So what should I do?
Old Aug 9, 2004 | 04:12 AM
skisax80's Avatar
well what i mean is, mice and other small things like to chew on wires and have some way of getting to places we normally wouldnt think is possible. not saying thats what it was lol, but u could try checking the back of the switch to make sure all the wires are good, if so, try ur best to trace them.. its possible that somewhere they chewd through the insulation and u have some wires touching....
Old Aug 9, 2004 | 04:15 AM
SkillZ25's Avatar
Ok i'll do that thanks for the help.
Old Aug 9, 2004 | 04:16 AM
skisax80's Avatar
if u cant find anything wrong, u may wanna try changing the switch or taking it somewhere that does electrical work...
Old Aug 9, 2004 | 04:20 AM
SkillZ25's Avatar
K, ty
Old Aug 9, 2004 | 04:22 AM
skisax80's Avatar
no problem, hope u can figure it out and get it fixed!
Old Aug 9, 2004 | 01:43 PM
kevm14's Avatar
Sounds like the HVAC flapper lost vacuum. There should be a line running from the intake manifold through the bulkhead connector to the dash area. Maybe there is a leak, or the actuator has failed.
Old Aug 9, 2004 | 01:48 PM
ishz28's Avatar
Have you tried looking at the 3 way vacuum connector in the engine bay, pass. side in front of the CPU. It's cheap plastic and breaks down over time. Mine had a hole in it, caused the air to only come out the def. vents. I put some RTV over the hole fixed like new.
Old Aug 9, 2004 | 01:58 PM
desertfox's Avatar
Just throw it out. Extra weight
Old Aug 9, 2004 | 03:03 PM
94z_convertible's Avatar
I had this same problem and it turned out to be the 3 way vacuum connector. Just buy a new one. Simple, cheap, and easy fix.
Old Aug 10, 2004 | 02:16 AM
SkillZ25's Avatar
Really? my dad said it might be somthin wto do eith the vac too. I'll check that out definatly thanks for the helps guys.
