Something is wrong, either I have a blown head gasket or i need a new opti
Here are the symtoms: Has hard time starting, backfires ALOT, i had one of my sparkplug wires on the wrong cylinder and it made the same backfiring sounds as it does now. But now the backfires are ALOT more. There sometimes is smoke coming out of the right side of my engine, and sometimes smoke out of my exhaust.
I do have headers, and no i didnt mess with my rockers. So you guys dont think it has anything to do with my opti? I dont want to change the head gasket and then not fix the problem. Head gasket isnt going to be a walk in the park.
Well im in the middle of a compression check and when i pulled the spark plug it had oil on it. Does that mean head gasket for sure or what? On the compression check, do you just check one side then the other or do you have to check each cylinder?
