Some updates on my car
Old Jul 26, 2008 | 01:54 AM
94arcticwhiteM6's Avatar
Some on here have helped a great deal in this project and for that i am very appreciative. so far the car is just about back together. i had to do the majority of the work myself as all my "bros" kept bailing on me. the timing set went back together without a hitch thanks to shoebox and injuneer. you guys know your **** for sure! the opti went back together nicely. my first major hurdle after that was the starter. somebody from last year posted a vid with symptoms exactly like i had, turns out you have to be careful where the PCM ground goes. big thanks to that guy i dont remember his SN. my last hurdle was the crank hub. i had the kentmoore set but it was missing pieces. i acquired a very expensive matco setup which is utterly useless for the LT1. so after 3 days of searching i found a 3 foot section of threaded rod. cut it down to about 7 inches and used a few washers and a bearing from a power steering pulley kit and it went on in about 5 minutes! tomorrow i can throw the radiator, condensor, and fans in as well as my new 1LE intake elbow. i did a test fire on it just to make sure everything was ok up to this point and the engine ran and idled well for about 5 seconds, so im hoping the last few pieces go in and i can finally drive it again. its been down for a long 6 weeks.
cliffs: resealed the LT1 and did a clutch and few other things. had some hangups gettin all back together. camaroz28.com came through for me and helped me out. should run in less than 24 hours.
again big thanks to all those that helped out in my threads especially shoebox and his site. as soon as i can i will be droppin a donation!
Feffman
Oct 9, 2015 05:42 AM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
wilsoncj6
Aug 4, 2002 05:23 PM
