some sort of leak
Old Mar 28, 2003 | 01:00 PM
ThotYouKnew's Avatar
some sort of leak
well it is coming from what i would say is the middle of the car....between the muffler and the transmission. Will an exhaust leak actually drop liquid? It only a few little dark dots.
Old Mar 28, 2003 | 07:55 PM
Josh-'04 GTO's Avatar
Your pinion seal is probably the culprit. VERY common on our cars.
Old Mar 28, 2003 | 11:07 PM
Thanks for the help, ill check it out...any other ideas?
Old Mar 29, 2003 | 01:24 AM
Rpm280's Avatar
Re: some sort of leak
What color is it?
Old Mar 29, 2003 | 05:34 AM
96ZRide's Avatar
Yes, when the car is first started, if you have an exhaust leak, condensation mixed with carbon forms a dark liquid and will find its way through whereever the leak is. Once the exhaust system is hot, you should not see any liquid leaking out of the exhaust system.
Old Mar 29, 2003 | 11:02 PM
very dark like black but not as thick as oil i dont think...
Old Mar 30, 2003 | 03:57 AM
Rpm280's Avatar
If it's that color, it could be what the person above said.... condensation mixing with black carbon in the exhaust , and comming out of a leak.
Only other thing I could think back there is tranny fluid out of the back of the transmission, but the would be RED, unless your fluid is veeeeery burned.
It could be again, condensation and carbon from an exhaust leak.
Old Mar 30, 2003 | 11:52 AM
OK guys thanks for the help. I think i found the link near where the piping bends to go up over the right axle. What is used to wrap this or do i need a new catback?
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 10:09 AM
rideordie
Sep 7, 2015 08:22 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
