Some Port Porn from Airflowdevelopment
Old Oct 20, 2006 | 01:41 PM
  #16
Hot94Z28's Avatar
Re: Some Port **** from Airflowdevelopment
Old Oct 20, 2006 | 03:21 PM
  #17
WS Sick's Avatar
That is awesome, whats the shortblock that this set-up will go on?
That intake has the cool factor going through the roof(and the hood...lol)!!!
Are those 23 deg heads?
Old Oct 20, 2006 | 10:21 PM
  #18
Z-RATED94's Avatar
What cam are you going to use? Those valve springs in the 4th picture look kind of puny.
Old Oct 20, 2006 | 11:15 PM
  #19
IllusionalTA's Avatar
Custom Solid roller.Spec's have yet to be figured out.. can't do all that till the heads are actually done... Comp Cam's said them spring's were good to over .800 lift and resist float to over 10K..
As far as the intake.. yea that's a sweet piece.. shame it's going on a sportsman class dragster or somthing or other..
And yes they're 23* heads.. Err.. 22 they've been rolled a slight bit...
Shortblock is a 396LT1 4 bolt block..
Old Oct 21, 2006 | 03:25 AM
  #20
FASTFATBOY's Avatar
Impressive no doubt, using a FAST or BS3 on that setup, Port CC as of now? Impressive to see a 23* head move that kinda air, thats 18* territory.
I am doing a similar deal with Pro Action(RHS) 220 And a super vic.
Damn I like lookin at this stuff, true **** on these pages.
David
Old Oct 21, 2006 | 06:13 AM
  #21
it's actually a tad under a 245.. Gonna run Accel Gen VII.. Who's doing your RHS'? what are you goal's?
Old Oct 21, 2006 | 07:49 AM
  #22
FASTFATBOY's Avatar
CFM in Indy is doing the conversion on the heads, Intakeelbows.com is doing the Super Vic conversion.
Then both will be sent to Jerry Killian down in south Ga to get ported. Or so I think I will as of now, I may let CFM or West COast Cylinder head do the porting.
Goal is 10.90 in a 3650lb Camaro all motor. With all the accessories intact on a 325/50 Drag radial.
Again, nice heads.
David
Old Oct 21, 2006 | 08:15 AM
  #23
Again, nice heads.
David
Sweet. .how big a cam you goin with? any specific's?
Thanks bro...
Old Oct 21, 2006 | 11:16 AM
  #24
Vicious95Z28's Avatar
Originally Posted by NightTrain66
Anyone that has Air Flow Development in their budget should go there. They have the knowledge that others only talk about having. They are the 'REAL DEAL'.
Dennis is an awesome guy with tons of knowledge. I always appreciate any morsel of advice they kick my way.
Nuff said!
Old Oct 21, 2006 | 01:09 PM
  #25
FASTFATBOY's Avatar
Thanks bro...
As of right now cam is up in the air..but I am thinkin 25x/26x@.050, mid 65x on lift installed on a 108...or something close..solid roller....up in the air as of now, I have the limit of stock ECM and opti.
David
Old Oct 21, 2006 | 01:35 PM
  #26
T/A KID's Avatar
Does anyone kow what is used to color Dyne Cylinder heads or where I can get it?? I have some AFR heads and I am wanting to Dye the AFR label on the front of the heads. It is purely Cosmetic and it will bring a little sytle to the heads.
Something along the color of this
http://www.afdracing.com/illusional/IMG_0234.jpg
Old Oct 21, 2006 | 02:46 PM
  #27
SStrokerAce's Avatar
Ben,
It's machinest dye.... normally the name brand is Dykem. It's a PITA to get off exactly where you want it off so be carefull with the stuff.
Steve,
Last time I talked to Dennis (yesterday or the day before I think) he said it was moving 365+ on 4.030" bore. In head porting terms you are looking at 103cfm/sq in, which if you talk to head porters is REALLY big air and basically unheard of on a 23° head ESPECIALLY on a 4.030" bore. Any head porter would be super impressed with this, be it Pro Stock, NASCAR Cup or whoever.
Bret
Old Oct 21, 2006 | 06:23 PM
  #28
marshall93z's Avatar
Awesome!
Old Oct 21, 2006 | 08:58 PM
  #29
Originally Posted by SStrokerAce
Ben,
Steve,
Bret
Hmmmm well maybe my math is wrong.. oh well.. I guess 365 will do...
Like i said before and i'll say it over and over again.. I'm continually impressed w/ his work.. he's got some great idea's.. and amazing knowledge.. way beyond my mind anyway.. LoL...
Old Oct 21, 2006 | 09:01 PM
  #30
T/A KID's Avatar
http://www.dykem.com/ProductFamily.c...chType=product
This stuff comes in a Marker, so it might not be bad, Thanks for the help Bret.
