some more 383 questions
Old Jan 24, 2008 | 11:49 AM
Soccerbum21's Avatar
a buddy of mine is liquidating his hot rod parts inventory out of his garage. i would like to use these parts to build up a new LT1 for my Z
he's offering me a deal on a 383 rotating assembly with the following parts for a 1 piece rear main '86 up hyd. roller engine
Speed Pro pistons (hyper.) 12cc dish 4 piston relief
GM "X" marked rods
Scat cast crank(3.750) with 350 journals
The balancer is a pioneer 8" and flexplate is 164 tooth
he's offering me this for a hundred bucks
my questions are:
how difficult is it to make everything work externally balanced (he said that would be the only catch)
would it be worth it to buy and build this motor (i already have a spare block, heads which i will get worked, intake manifold, and oil pan)
are those rods and pistons good enough for a 150 shot of nitrous
how big of an injector should i be looking at to replace the stock ones
thanks in advance
D1SC383LT4
Jan 1, 2016 01:56 PM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
