Some Help From the Pros!
Old Sep 29, 2011 | 10:34 PM
ShowOff67's Avatar
Hey guys im doing a full top end rebuild on my 95 z28 M6 motor is still in car. I mean everyone says its so hard to work on the lt1 when its in the car but i just prefer it the best i dont know why. bought around 500 dollars in parts for a job that the shop told me it would be 1800 per head gaskets. and i needed a new optispark. Not having anyproblems, always wonder why i had low oil pressure then i took my intake off and saw my oil pressure sending unit was broken barly hanging on lol. Well Anyway i need to know if i can Replace the rear main seal while the motor is sitll in the car. i have been told i need to loosen motor mounts and raise motor alittle bit. can anyone give me a detailed walkthrough for what i need to do if it is even possbile to do. and yes my rear main seal is bad oil was not comming from anywhere esle. Car was sputtering and backfiring and i didnt know it was a sign of a bad optispark but then also my radiatorfluid was milkshake oily, so i got full gasket kit, new rollers and rods, new rockers, plugs, opti, wires, Thanks!!!
Shot me a email if you want, Skatepunkiam@yahoo.com
Old Sep 30, 2011 | 11:45 AM
raroz28's Avatar
Re: Some Help From the Pros!
It's easy to do this job in the car. Once you remove the fan, radiator, intake, alternator, and valve covers you're pretty much done. It's very easy.
Rear main can be done easily on the car. I did it 2 years ago. You will have to drop the transmission to get to it though.
Once you rebuild the top end it should fix the sputtering problem seeing as how your oil looks like chocolate.
This job can be done in a day if you have headers. If you have stock manifolds the biggest pain is going to be getting the Y pipe off and dropping the manifolds.
With my exhaust setup I can drop the Y pipe and have the headers off in no time. You will definitely not be so lucky with stock manifolds.
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 9, 2015 03:33 PM
