Solid Spacer and pinion nut.
Old Jul 13, 2003 | 10:03 AM
xxsaint69x's Avatar
I was thinkin about changing my pinion seal as it has tinnnny leak. Can i tighten the nut as hard as i can afterwards? I know u cant with the normal crush sleve, but since i have the solid crush sleve will i mess anything up?
Marcin
Old Jul 13, 2003 | 12:07 PM
MYT30TH's Avatar
I just got done setting up my gears & put a ratech solid spacer in mine.... proper torque setting for the pinion nut is 125 foot pounds.
Old Jul 13, 2003 | 12:16 PM
Do you remember what size the pinion nut is? I want to make sure I have a socket for it when I do my gear work. Thanks.
BTW, Marcin, I don't think you would have any problem since you have the solid spacer. That is a benefit I had not thought of before.
Old Jul 13, 2003 | 12:30 PM
MYT30TH's Avatar
shoebox, the pinion nut is 1-1/4" , and like you said changing the seal wont cause any pre-load changes on the bearing.
Old Jul 13, 2003 | 12:46 PM
Thanks.
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
