solid roller setups....
Old Sep 14, 2004 | 11:05 PM
firetird's Avatar
what kind of solid roller lifters are you guys running and do they require any machining to the block? i was looking at the crane cams 11522 and the comp cams 888. anyone using these? what are you opinions on them, or any other ones?
thanks
Bobby
Old Sep 14, 2004 | 11:53 PM
TCAL95Z's Avatar
Re: solid roller setups....
I think you will get a couple comments from guys not liking Crane Solid roller lifters or atleast that part number you mentioned.
I purchased some Crane Solid roller lifters from Thunder Racing but the part number is different
on my box it has 10510 & 2-2404
Thunder racing told me these were direct replacement and that they had good luck with these.
I'm trying to find out more before I use them.
Old Sep 15, 2004 | 06:14 PM
SILVERZZ28's Avatar
Don't Use Cranes ! My Motor Is Down Becuase Of Them. Go Isky
Old Sep 15, 2004 | 09:40 PM
lillbush5555's Avatar
The reason most people are having problems with the crane 11522's is because they are using the comp cams 943 spring. I went through this to and I talked to jason. He explained to me that the reason the 11522's fail is that the springs 943 are too strong for those lifters. If you plan on using a softer spring (I am using comp 954) they should have NO problems
Matt
Old Sep 15, 2004 | 10:46 PM
TCAL95Z's Avatar
SilverZ,
What springs were you using? Approx how high is your lift?
What happened?
Lillbush,
Are you using them?
According to my box I don't have that part number
Old Sep 15, 2004 | 10:55 PM
They might have changed them. I am running them,
Matt
Old Sep 15, 2004 | 11:10 PM
TCAL95Z's Avatar
Hi Matt,
Nice web site. I just looked on your site and the lifters I have look nothing like your crane lifters. They don't even have the bars connecting them.
The part numbers I have on my box are 10510 & 2-2404
Thunder racing promised me these were the right ones.
Old Sep 15, 2004 | 11:17 PM
the 11522 arent the only ones that fit. I am sure they will fit. Thanks on the webpage still trying to get it a little better, But thanks
Matt
Old Sep 16, 2004 | 07:47 PM
firetird's Avatar
also what are you guys doing about the km?
Old Sep 16, 2004 | 10:08 PM
TCAL95Z's Avatar
I looked up on Cranes web site and they list my part number(10510) as being the correct one but they call them a standard solid roller lifter.
I would still like to know if anyone has had problems with them.
As far as the KM I have heard you can't use it. I haven't looked into that yet.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
