Solid roller question
Old Mar 18, 2003 | 08:41 PM
SILVERZZ28's Avatar
Ok this is prolly a stupid question but I was wondering if I can go to solid lifters? I am running a billet GTP-6 cam with Hydro.lifters. I believe you can't because of the different cam profiles (lobe ramps) but I wanted to make sure......
Old Mar 19, 2003 | 09:51 AM
SILVERZZ28's Avatar
TTT
Anyone. Maybe I need to put this in the advance tech?
Old Mar 19, 2003 | 10:11 AM
Mindgame's Avatar
No, you cannot use solids on a hydraulic lobe. Solid cams are ground with a clearance ramp ground into the ramp to take up the lash clearance and gently get the lifter onto the lobe. Hydraulic cams do not have this clearance ramp.
People have done it but the valvetrain usually comes to an early demise.
-Mindgame
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
