Sodium Filled Exhaust Valves
Old Jun 4, 2003 | 11:30 AM
EvlViln's Avatar
Question Sodium Filled Exhaust Valves
Does Anyone know who made these for GM for the LT4's? Thanks.
Old Jun 4, 2003 | 04:29 PM
EvlViln's Avatar
anyone?
Old Jun 4, 2003 | 04:50 PM
quicksilver97ta's Avatar
Just curious, why don't you think GM made them?
Old Jun 4, 2003 | 05:36 PM
Mindgame's Avatar
I read somewhere that TRW manufactured them.
-Mindgame
Old Jun 5, 2003 | 12:18 AM
EvlViln's Avatar
GM farms out a lot of work on short run vehicles. For example, the LT5 was almost completely made by sub contrators and assembled by GM. GM doesnt put Sodium Filled Exhaust Valves in any other engine. so it would make fiscal sense that they bought them from a company who already makes them, instead of buying all the tooling to just put them in an off shoot version of an engine that only went in a few cars for one year.
You can buy them from GM but they only come in 1.55 and i would really like a set in 1.60. But all i am doing is seeing if that is even possible. So far i cant find out who makes them. Subaru, Volkswagen, and Nissan have all used them in other cars and they too probably bought them some where i just need to find out where. Thanks.
Old Jun 5, 2003 | 02:40 AM
Dr.Mudge's Avatar
Just make sure to avoid the coffee, and I think you'll be fine.
Old Jun 5, 2003 | 04:52 PM
Mindgame's Avatar
Originally posted by Killerjello
trey works there i believe its gonna be scary with parts he works on
I have a feeling that they keep Trey as far away from the critical stuff as possible Jason.
Evl one,
Check with SBI too:
http://www.sbintl.com/
Good luck.
-Mindgame
Old Jun 6, 2003 | 01:57 AM
EvlViln's Avatar
Mind game thanks for the help.
You rock!
Old Jun 6, 2003 | 02:19 AM
lt4 fd's Avatar
Whats teh advantage of sodium filled exhaust valves, weight or heat related properties????
Old Jun 6, 2003 | 07:45 AM
LT1derful's Avatar
interesting thread...good info.
Old Jun 6, 2003 | 08:34 AM
Exactly, light weight and heat dissapation. LT4 heads use sodium filled exhaust valves and hollow intake valves. AFAIK
Old Jun 6, 2003 | 08:38 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
they let me in the SRt-10 yesterday MG
I am in braking systems, not "components"
i can get viper calipers, rotors and hubs-
but i cant get a standard SBC exhuast valve
hopefuly i can pull some strings and get some new rotors for my truck-
deep puddles + sand + hot rotors =
trey > mindgame > eye crusties
hooooooooooo!
Old Jun 6, 2003 | 11:54 AM
EvlViln's Avatar
Quicksilver is right. 100%.
The exhaust valve get really hot, and when the cylinder is trying to fill cold air hits the exhaust valve and warms up (also cools the exaust valve down), so the SFEV have MANY advantages in our applications. I have even heard on the grape vine that all Z06 has SFEV's. But that might be a fable. At any rate, SFEV run cooler because the disburse heat from the head of the valve and into the stem. Turbo'ed cars use SFEV all the time to try and keep exhaust temps down. And on NA motors is helps valve train longevity at high RPMs where heat build rapidly. So it would have more benefit for the Auto-X or Road course, than Drag racing. They are rare and expensive, if you have a supercharger, turbocharger or even nitrous it can be beneficial. And from what I am finding out, very hard to find.
Old Jun 6, 2003 | 12:34 PM
jomo_eng's Avatar
GM also uses these in there Small Block Fast Burn heads. Great flow numbers on those by the way.
Later,
JoMo
Old Jun 6, 2003 | 04:39 PM
Mindgame's Avatar
Yes, the Z06 utilizes a sodium filled exhaust valve along with hollow stem intake valves. 2002-up model valvetrain is actually a bit lighter than earlier models.
-Mindgame
