So lets talk throttle body options...
Old Feb 23, 2006 | 10:46 PM
HardcoreRM125's Avatar
Not a huge selection out here but, whats the pros/cons of each?
58MM with N20 Passages
58MM VS 52MM On a FI 383?
Would there be a significant difference running a 52MM versus a 58MM with a ported intake?
How hard is it to home port-match the 58MM to the intake manifold without much other than a dremel?
Anyone ever successfuly do a monoblade conversion? What all would be involved in that?
I plan to make a supercharged low compression 383, and I think it would be worthwhile for me to go to twin 58, versus 52 since its oging to be a FI motor when im done with it. I dont really know if their enough to bottleneck it or not though?
Any other questions/comments?
Throttle bodies havent been discussed in here for quite some time now.
Old Feb 23, 2006 | 11:08 PM
Evil Eric's Avatar
Re: So lets talk throttle body options...
Most say that a stock TB will work for any application, and some swear that bigger is better. I went with a Holley 52mm for my H/C 355.
Old Feb 24, 2006 | 01:12 PM
Since im going to build a 383 Forced Induction motor, either procharged, or some type of turbo, or twin turbo, set up, I figure I cant go too big for the #'s I want to make
So really all I was looking at was 58MM, and seeing if anyone ever converted to a mono-blade stlye like an LS1 has. I was wondering how extensive that could be ($$$) because it didnt really seem like it would be worth it? Hard topic to find anything on too.
Old Feb 24, 2006 | 01:16 PM
aggiez28's Avatar
AS&M makes a monoblade for the lt1.
brook
Old Feb 24, 2006 | 01:23 PM
Interesting ... Thanks.
Any idea what all would be involved in getting one of them to fit ( What would need ported. Could it be done at home like a 58MM can? )
Old Feb 24, 2006 | 01:28 PM
I just looked on their site, all they have is twin 54MM and 58MM, no monoblade on their site?
Old Feb 24, 2006 | 02:15 PM
Jeff95TA's Avatar
That's wierd. Thunder Racing shows them:
http://www.thunderracing.com/catalog...vid=4&pcid=180
Old Feb 24, 2006 | 03:09 PM
blkchevyz's Avatar
58 will be fine if you match the intake to it.
monoblade will be over kill, specially on a supercharged car, the airs going to get forced in either way lol
Old Feb 24, 2006 | 03:13 PM
FastZinTennessee's Avatar
I think that's because there isn't much information out there to be had. Perhaps I have overlooked it, but I have never seen a back to back comparison between a stock TB and a 52/58mm. Once I get my car running right I plan to do a back to back dyno comparison if I can find a 52mm TB to borrow for a few hours. I would like to compare a 58mm also, but my intake is not matched to accept that size.
Old Feb 24, 2006 | 03:30 PM
blkchevyz's Avatar
we did that on a buddy of mines car.
he had normal bolts on with the 305 cam.
he gained 8-10 hp going from stock to the 58
it wasnt just peak hp, it was from 2k to 6k
Old Feb 24, 2006 | 03:32 PM
Stock heads?
Old Feb 27, 2006 | 06:52 AM
blkchevyz's Avatar
yep stock heads
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 22, 2015 02:45 PM
