CamaroZ28.Com Message Board
-   -   So if I get a 160* stat and dont get my pcm reprogrammed what happens? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/so-if-i-get-160%2A-stat-dont-get-my-pcm-reprogrammed-what-happens-341829/)
IrocManiac Feb 15, 2005 09:27 PM
Just curious...I may be buying a new stat pretty quick and wont be able to afford a repogram of the pcm, at least it isn't looking likely in the nearing weeks. I doubt I'd do this just wondered what would happen. I'm going to probably wait, get a 160* and get a pcmforless tune in the next couple weeks...thoughts? suggestions?
badazzcamaro97 Feb 15, 2005 09:46 PM
Re: So if I get a 160* stat and dont get my pcm reprogrammed what happens?
I did this before my tune, and all I noticed was it lowering temperatures like its supposed to.I dont think there will be anything bad.
IrocManiac Feb 15, 2005 09:49 PM
friend did it said the same thing, but my question is why do you have to do it if it works without the tune?
ChickenScreamer94 Feb 15, 2005 09:51 PM
nothing bad happens. a tune with a 160 stat can let you advance ignition timing a degree or two and programs the fans to come on earlier.
IrocManiac Feb 15, 2005 10:02 PM
cool, thats kinda what I was thinking but wasn't sure
phinger23 Feb 15, 2005 10:04 PM
you wont get the full benefit of the cooler system...but it will be ok. the fans are factory programmed at i think 235 or so.
shoebox Feb 15, 2005 11:56 PM
As I said before, you don't have to get a reprogram. :)
94Z & 96SS Feb 16, 2005 12:00 AM
I put in a 160 without a program(HPP didn't work when I got it). If you drive in alot of stop and go traffic you will notice the temp go up and down alot. If you mainly do highway driving you probably will not notice anything except for your temp being lower.
SSmoked Feb 16, 2005 12:04 AM
My car never gets above the second line(200?) I have the 160 thermostat and madwolf tuned my PCM, i love it. Even idleing for 30 minutes it dosint budge.
IrocManiac Feb 16, 2005 07:54 AM
cool, i'll probably get the 160, get a couple paychecks under my belt and go with a pcm.
