so, i found my ticking noise...
Old May 12, 2006 | 06:41 AM
  #16
limige's Avatar
Re: so, i found my ticking noise...
Originally Posted by TraceZ
^^ that was my first thought.
i had the valve springs done at a local machine shop, we went over the cam lifts, spring rates ect. they aren't binding...
i set these as per the book, 3/4 turn past zero lash..
i'll have to check the other rocker slots, i didn't notice any strange wear.
more than anything i'm worried about my lifters and whether or not it could be a valve float issue.
other than that i was curious about the guideplates, they looked ok to me thats why i put them on..i planned on doing the rr's soon so i figured i'd go ahead and install the plates, not that they were really needed.
so when i install the pro mags 3/8 studs how far past zero lash should they be set?? 1/16-1/8?
what's a good lifter to use, are OEM's for the lt1's good or should i go aftermarkets?
Old May 12, 2006 | 07:23 AM
  #17
KGRESOCK's Avatar
Did you use GM guideplates?
Old May 12, 2006 | 08:36 AM
  #18
limige's Avatar
no, they were comp cams flat plates.. anyone got a link to the gmpp ones?
Old May 12, 2006 | 01:51 PM
  #19
Z95m6's Avatar
http://shbox.com/1/guideplate_compare.jpg
Old May 12, 2006 | 03:23 PM
  #20
limige's Avatar
interesting, i placed an order through thunder racing for new plates and rods...already got the pro mags so hopefully things will go better this time around..
brothaslide
Jan 9, 2016 12:11 PM
Wart Hog
Sep 8, 2015 05:53 AM
Aug 17, 2015 09:50 AM
meissen
Aug 11, 2015 06:05 AM
Boss002
Jul 9, 2015 03:33 PM
