Smoke from dipstick and oilfiller cap??
been having a TON of problems with my car lately...you may have seen my previous posts....or not
Any way, i put new rods and main bearings in today. cheack all clearances. mains were all about .021-.025 rods were all about .020-.025 ....seems kinda tight? but i dunno how acuright plasigage is.
well put oil in it, Exon superflo 10w-30. took is for a 30 mile spin. never went over 3k rpm, never gave it alot of gas, never let it really idle that long.
oil pressur and all looked good, lil high at first, but it cam down to regular.
Heres the odd part. pulled in to my driveway and shut it down. i pulled the dipstick out and there was smoke coming off of the dipstick and smoke coming out of the dipstick tube. by no means was it billowing, but there was a lil smoke and the oil seems hot.
I have no oil cooler
water temp was good at 170 or less the whole time
There was clevite77 red stuff assembly lube in it
anythoughts of what that means? thingk it was the oil or something else?
I've had my cars throw a little smoke from the oil filler before when up to operating temp, but I can't recall it coming from the dipstick tube. I really wouldn't worry about it if everything checks out ok.
John
John
mmmmk
well i will take it as is comes i guess. i will put another 20 or so miles on it, then put it some mobil 1. synthetics have a high heat tolerance and should hold up better...in theory
i have the worst luck
typo on the clearances
Actully everything in new, cept for the shortblock. I bought it from a friend with "40k miles on it, is good working order"
So it very well could be the rings. I just changed the oil so i will see how that goes
Originally posted by gb95zconv
Man I hate to say it but that sounds like a piston/ring problem.....thats what my engine was doing when I broke a ring land. Check your compression.
What are other symptoms of this? i plan of doing a compression check but just currios if there are others
One other thing that can cause the problem you are having is a faulty PCV valve.....check it.
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
