Smells rich and backfires...
Old Sep 16, 2004 | 12:58 PM
GpMike24's Avatar
Right now you can definately smell my car, smells like gas. Also tends to back fire alot and at high RPMs tends to even cut out. I have 30# inj. and am thinking that i need some 25#s. Thinking maybe i'm dumping too much fuel into it and possibly fouling out the plugs. Any advice would be great.
Old Sep 16, 2004 | 01:16 PM
Spinner's Avatar
Re: Smells rich and backfires...
If its not programmed for 30# injectors, thats causing your problem. If it is, it shouldnt make a difference.
Old Sep 16, 2004 | 07:05 PM
GpMike24's Avatar
i got my pcm programmed by pcmforless but i dont believe that it is set for 30#. Do you think it would work better if i went with some 25# rather then reprogramming and just keep the 30s for a later time, i sure hope so this is really getting old fast thanks for any and all help
Old Sep 17, 2004 | 11:59 PM
94IMPALASS's Avatar
Drop me an email with your name and I will check what injectors you are set up for. Also send me some data logs if you can and I can look and see if there are any problems with sensors.
thanks,
bryan
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
HAWG
Sep 25, 2015 11:41 AM
damnyankee36
Sep 9, 2015 07:06 PM
