SLP thermostat
Old Aug 13, 2007 | 01:17 PM
Black6spdZ's Avatar
SLP thermostat
I have installed 2 of these now, and neither open at 160, my car runs at exactly at 180 according to scans. I was wondering of there is another option or what others are doing.
Scott
Old Aug 13, 2007 | 01:27 PM
94LT1350's Avatar
i didnt think having a 160 thermostat meant it will run at 160. the thermostat just opens at 160. my 160 allows the temp to run at 175.. they came stock with hotter thermostats( i think 180 or so ) and ran 210.
Old Aug 13, 2007 | 01:30 PM
speed_demon24's Avatar
160 degree thermostats beging to open at 160 degrees, they aren't fully opened at 160 degrees. With a becool radiator and my hypertech 160 degree thermostat my car runs at 169 according to my scanmaster with the fans on or on the highway.
Old Aug 13, 2007 | 01:31 PM
WestCoast96Z28's Avatar
With 160 and stock radiator, coolest it will run is a little under 185 (according to the dashboard) going at highway speeds.
Old Aug 13, 2007 | 01:51 PM
Scott
In the summer heat, that sounds normal. If you had a 180 thermostat, you would be running at about 200.
Old Aug 13, 2007 | 02:51 PM
Black6spdZ's Avatar
ok, thanks for some reason the 160 i have in my truck holds a temp closer to that, i just wanted to make sure mine was working correctly.
Scott
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
