slp loudmouth for 1997?
Old Dec 10, 2004 | 07:27 PM
95camaro3400's Avatar
where is the cheapest place online to buy this catback system for a 1997 z28? thanks
Old Dec 10, 2004 | 07:47 PM
oneledvr's Avatar
Re: slp loudmouth for 1997?
Buying directly from SLP is just as good as any place.
Old Dec 10, 2004 | 08:04 PM
on slponline.com the only loudmouth kit on the site says its for the 98-02 fbodies, will this kit work if i purchase the installation kit im looking for a kit that is direct bolt up and will it sound like it should on anm lt1 even though it says its for an ls1? thanks
Old Dec 11, 2004 | 07:14 AM
Schweet97Z's Avatar
it will work.....they have an lt-1 install kit......what i had done was took it to a local exhuast shop and had them make me a little peice of piping and had them weld it in......simple and easy!!!!
Old Dec 11, 2004 | 09:34 AM
oneledvr's Avatar
Personally, I would just call them on the phone and tell them you have a 1997 Z-28 and you want to order the L/M Cat Back Exhaust System.
It worked for me!
Old Dec 11, 2004 | 01:59 PM
ellootre's Avatar
It worked for me!
Did that run any more than the standard kit?
Old Dec 11, 2004 | 04:17 PM
ExStyle's Avatar
The loudmouth will fit your car with an install kit. They make two diferent installs kits for the lt1 4th gen. One for the 93 and one for the rest. The install kit will run you $30 and includes two exhaust hangers and a rubber isolator. Both hangers are to hold the pipes up after the axle. I ordered mine through ls1speed.com great service and got here fast. Mine was around $380 shipped for everything. (I have a 93 which requires the other install kit which runs for $70 anywhere else but ls1speed takes a hit on it and only charges $30, good place)
Old Dec 11, 2004 | 04:45 PM
oneledvr's Avatar
yea what he said. I ordered mine through SLP when I ordered the system. I think it was like $45.
When I installed my L/M I fit everything together in my garage loose before I tightened anything up and trimmed the tail pipes before I installed the slip on tips. If you do not trim the tips they will stick way past the bumper. Looks like Siht to me. Once, I had everything aligned evenly and made sure there was not going to be any contact points on suspension etc. I tightened the front slip on clamp and the clamp above the axle and I marked all the rest with sharpie marker and removed the marked items and went to Tuffy and had them weld the drivers side tail pipe and the two (dual dual) tips inplace. It turned out awesome. If you don't weld the tail pipe and the tips they will have to be clamped, once again looking like siht. Just my opinion. I hope this helps!
Good Luck.
Jim
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
n2oblkz
Oct 12, 2015 01:53 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
