SLP line lock install
Old Jul 21, 2004 | 11:22 PM
madwolf's Avatar
Arrow SLP line lock install
I just installed an SLP line lock and when I went to route the wiring, I found that they forgot to include the 3 pages with the wiring install.
From looking at the wiring, I think one of the wires (with the fuse) goes to the red junction box (+) and the other end connects to the solenoid. Which connector should it connect to on the solenoid side? Top/bottom?
The other wire with the switch connects to the other connector on the solenoid, then goes inside the car. I noticed another terminal which is most likely for the ground... possibly the one under the (steering column) panel?
How did you guys get the wire inside the car? Where did you install the switch?
Thanks!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
