Slp Cai?
Old Aug 3, 2004 | 07:29 PM
99BlackTA's Avatar
Slp Cai?
I am thinking about switching from my Moroso CAI to an SLP CAI. I have found a couple that are used for sale. I was wondering if there was a big difference on one that said it is specifically for the 93 LT1 motor and I have a 94. Said that it had something to do with the length because of not having a MAF sensor. Is this true?
Also can you use the K&N cleaner kit on the filters for the SLP?
Old Aug 3, 2004 | 07:47 PM
importeater's Avatar
Re: Slp Cai?
I have a 93 SLP intake on my 97. Its a bit of a PITA to get cut right but if you have access to a machine shop or the right cutting tools its not that bad. You end up cutting about 2-3 inches off and then having to make a connector. I used a rubber pvc to cast pipe adapter and it works great. Like I said its not a big deal but if you can find one for $20 or so more that you dont have to cut, its worth it!
Craig
Old Aug 3, 2004 | 08:40 PM
Somnambulist's Avatar
Re: Slp Cai?
is there a difference between the two? no...
keep your moroso...
Old Aug 3, 2004 | 08:48 PM
99BlackTA's Avatar
Re: Slp Cai?
I just read the post a while back and almost everyone's vote went towards SLP for being the best CAI. It also looks great under the hood.
Old Aug 3, 2004 | 08:58 PM
Re: Slp Cai?
all CAI's prove similar numbers. the SLP won't make any more power than the Moroso...
Old Aug 3, 2004 | 09:26 PM
unvc92camarors's Avatar
Re: Slp Cai?
doesnt that metal piping weigh more (really negligible) and keep heat in more?
G-BODYT56
Jan 14, 2022 11:14 PM
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
n2oblkz
Oct 12, 2015 01:53 AM
SEOJustin
Sep 24, 2015 04:39 PM
