slp cai
I haven't done much offroading in mine
, but you'll probably be ok. You'll probably have to clean them pretty often, though.
Could be wrong and if so, plenty of people will chime in.
, but you'll probably be ok. You'll probably have to clean them pretty often, though.Could be wrong and if so, plenty of people will chime in.
just check very often that your folter cans are still on, i had a slight problem with them staying on for the first few times i put new ones on. but yeah, you'll be fine, thats what the filters are for.
i will keep my cai on even if i do ram air. they cai takes in cold air from under the car, and the ram air takes in hot air from the top of the engine. plus the ram air isnt effective until like 100mph. ill use the ram air for "cooling ducts" if i get my ram air II hood
