slight ticking..
Old Sep 13, 2004 | 09:10 PM
GreenZLT1's Avatar
slight ticking..
I have a ever slight ticking coming from the back part of the motor. It doesnt seem to be there all the time, only when its really been warmed up. I can kind of hear it inside, but its more of a wooshing tick noise, sorta like an air leak. The sound is also on the drivers side in the interior. Would this be a leaking exhaust manifold?
Rob
94 Z28, Green
Old Sep 13, 2004 | 09:34 PM
CCCCCYA's Avatar
Re: slight ticking..
more than likely it's gonna be exhaust... Check the bolts and make sure nothing "backed out". A 94 has had plenty of time to get loose you know
Dave C.
Old Sep 13, 2004 | 11:05 PM
BlownF1's Avatar
Check the risers on the exhaust manifolds too...mine were loose and took forever to find. I was certain I had a bad lifter, and found it by pure luck.
Old Sep 14, 2004 | 12:12 PM
JDW18's Avatar
risers not sure what those are but i got ticking to i think its a leak in the egr valve going to my headers
Old Sep 14, 2004 | 08:12 PM
97Transam123's Avatar
i had a tciking noise at the rear of the motor it turned out to be a loose spark plug on number 7 cylinder and the heat shield was ticking agianst the cylinder head..... but mine was more of a uniform tick not a air blowing tick....
i love describing ticks
Old Sep 19, 2004 | 11:38 PM
BlownF1's Avatar
The risers are the vertical tubes coming off the exhaust manifolds that point upward. The smog pump runs over to each side to inject air into them at startup. I don't have a picture handy, but someone might...
magman
Apr 15, 2016 03:08 AM
jayblev95
Sep 26, 2015 09:44 PM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
techstar
Aug 6, 2015 11:20 AM
