Slight Intermitent Stumble
Old Jul 23, 2011 | 06:47 PM
Red97LT1's Avatar
After driving for a while and letting the car set,it will stumble when started. It almost dies,but doesn't.Doesn't happen all the time.It will do that for a few minutes and then will run fine,and it may or may not do it on the next start.I replaced the TPS sensor since it was under warranty,but it didn't help.There aren't any codes in the computer either. The car still runs strong after that initial hiccup.I have been smelling a slight hint of gas,but not sure if they are related.Any ideas?
Old Jul 23, 2011 | 10:51 PM
mrmint69's Avatar
Re: Slight Intermitent Stumble
What all has been done to the car? Might be something simple like needs a tune up or replacing the fuel filter. Have you done any maintence on the car latley? There are several things that need to be kept up on on these cars, so it help to know how well the car is kept up.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
