slave/master cylinder and lines all come together
i am in the process of getting a new slave and master cylinder, resovoir, and lines. i was wondering if they come all as one unit. i thought they did but i took the part # 12557509 to the local shop and they said that was the master cylinder. the slave cylinder and lines were seperate according to them. a part # would be great if they all come as one unit. its a 95 t-56. thanks
The only way you can buy it is as one whole prebled assembly.. I'm 99% positive that's the only way it's available from GM.. I know that's how I bought it..
I don't have a part number though
sorry.. I'm sure someone here does. You are on the right track though..
P/N 12557509 is a complete assembly and it even comes with fluid!!!!! I bought a swap kit 6-speed and I just replaced the whole hydraulic assembly from a local dealer for 101.25+ 7.09 +tax=108.34. Laugh in that dudes face when he hands you the whole assembly, Mmmmmmuuahhhhhhhhaaaaaahahahahhaha! Later ~~~~~~rob
It's not too bad. I managed to do it without removing anything else to do it. The hardest part is getting the U-bolt out that holds the master cylinder to the firewall. I just replaced it with two ordinary bolts and locknuts.
Found 2 pics of the entire assembly as it comes in one piece
http://www.bfranker.badz28.com/misc/masterslave1.JPG
http://www.sallee-chevrolet.com/Chev...s/12557509.jpg
was looking for something like this and thought i might share
yeah, getting that thing up there and attached to the firewall was a PITA!!
I never thought to trash the u bolt for two seperate bolts, I bet that would have made it a lot easier.
Really, it's not a very big job.. it takes a little patience as does everything on these cars..
I never thought to trash the u bolt for two seperate bolts, I bet that would have made it a lot easier.Really, it's not a very big job.. it takes a little patience as does everything on these cars..
A local dealer only charged 101? Thats incredibly low. Freakin dealer here wanted 231. I called Dal and he got it to me overnight saturday delivery for 120. Couldn't beat that with a stick. Too bad the clutch still doesn't completely disengage.
It is one complete sealed unit. I bought mine locally for $105.
The u-bolt is a major PITA to get in there and everything aligned properly.
I was about ready to throw things while I was working on it.
It is very difficult to get up under the dash to work with the bolts.
I was about ready to throw things while I was working on it.It is very difficult to get up under the dash to work with the bolts.
carguyshu
Jan 22, 2017 11:19 AM
supercharged94Z28
Jun 2, 2015 03:32 PM
Chris Anderson
Jan 27, 2015 08:30 AM
