Size of water pump O-ring?
Old Mar 12, 2004 | 02:16 PM
JJ's95B4C's Avatar
Does anybody know what size the water pump o-rings are? The nearest dealership that actually has them in stock is ~1.5 hrs away. I know the local parts stores have o-rings, but i need the size. Does anybody know?
Old Mar 12, 2004 | 06:37 PM
tagz's Avatar
Not sure what size they are. But if you REALLY can't find one, i can send you a couple... I have a few left over from mine, 10 came in a pack.
part number is 12553792
..I'm assuming that you are referring to the o ring that goes on the shaft coming out of the timing cover? Or are you referring to the seal that goes in the timing cover?
Old Mar 12, 2004 | 10:51 PM
JJ's95B4C's Avatar
I appreciate the offer, but i'm going to be installing this tomorrow, and i really can't go another week without a car. I'll just wake up early tomorrow and make the drive to the dealership! And yes, i was talking about the o-ring on the spline shaft and not the actual timing cover seal.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
pologreen97z
Dec 2, 2014 10:42 AM
