Size of the torx bolts for the opti rotor?
Old May 29, 2006 | 02:53 PM
always faster's Avatar
I need the size of the torx bit that i need to take the opti rotor off.
Is it a T8 or T9?
Thank you
Old May 29, 2006 | 04:57 PM
anaik's Avatar
Re: Size of the torx bolts for the opti rotor?
T9 is the correct size. Sears has torx screwdrivers in that size, couple of bucks. Don't have to buy a set.
Old May 29, 2006 | 10:25 PM
sam pace's Avatar
find a t-9 torx screw at the hardware store and it will only cost you $.50
if you have an old q-jet carb laying around the top screws will fit the opti screws.
Old May 30, 2006 | 01:20 AM
lt11997's Avatar
Use one of the throttle body plate screws as a socket.
Old May 30, 2006 | 05:47 AM
Mtrhds94Z's Avatar
That works for the 4 cap screws, but not the 2 rotor screws.. rotor screws are T9 Torx..
Old May 30, 2006 | 05:57 AM
anaik's Avatar
[QUOTE=sam pace]find a t-9 torx screw at the hardware store and it will only cost you $.50
How can you remove a T9 screw with another T9 screw?
Old May 30, 2006 | 07:09 AM
Procharged94Lt1's Avatar
[QUOTE=anaik]
He meant get a female head screw and use it to take the male screw out with..
Old May 30, 2006 | 09:45 AM
Bill_Mitchell's Avatar
heck I thought it was a 4....and I still couldn't find it.
Old May 30, 2006 | 04:38 PM
Mtrhds94Z's Avatar
[QUOTE=Procharged94Lt1]
The rotor screws are female heads..
Old May 30, 2006 | 08:16 PM
[QUOTE=Mtrhds94Z]
sorry- either way the idea and point should have gotten across
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 16, 2015 09:45 AM
