Single Plane project finally completed...
Old Nov 12, 2006 | 04:04 PM
  #76
526 SS 96's Avatar
Originally Posted by blackz97
I also read somewhere that the single plane will feed the cylinders more equally to help prevent any individually hot cylinders.
Steve
That can't be true. The LT-1 intake IS a single plain, it just has short runners. The other reason I don't think that is possible is because there is one injector for every cylinder that injects fuel directly infront of the port. You may have been thinking if a carbed setup. I think that the AF range is in the lean/ fast range. I always shoot for mid/low 12's for AF.
Old Nov 12, 2006 | 05:07 PM
  #77
Jerm93z28's Avatar
all the air has to enter the plenum at the front of the LT1 intake, so the rear cylinders can get starved. another theory is that some of the cylinders that fire adjacent to one another can rob one another due to such a short runner being side by side. (i think thats how that goes)
with the single plane, the air enters at the center of the engine, which helps the rear cylinders.
Old Nov 12, 2006 | 06:01 PM
  #78
Turbo6's Avatar
526 SS, unfortunately, the tracks are closed for the year here, at least at IRP. I'm sure that I'll have my mid/high 10 @ 128 which is the goal on motor before the nitrous goes on the car in the spring. That being said, to justify the swap, I'm going to have to find some more power so we'll see what we can figure out over the next weeks.
Old Nov 12, 2006 | 07:52 PM
  #79
blackz97's Avatar
Yeah thats what i was looking for. I had read that more then once before.
Steve
Old Nov 13, 2006 | 08:17 PM
  #80
GreenbeanZ28's Avatar
What'd the car run before? If the car is full weight, realistically you'd be closer to a mid to lower 11 sec/124 mph run I'd think. Looking at the two graphs, honestly I think the car is going to run a similar ET with a 2-3 mph higher trap speed.
Old Nov 13, 2006 | 08:40 PM
  #81
96capricemgr's Avatar
Dynos do not tell the whole story but a midrange loss over that broad an RPM range is going to be hard to overcome at the track. I sincerely hope you find an issue and this is not as a result of the intake swap.
Old Nov 13, 2006 | 09:07 PM
  #82
Turbo6's Avatar
The car ran an 11.9 @ 122mph on street tires before the swap, spinning. Given the fact that the RPM range will be between 5500-7100rpm for each gear at the track, I expect it to pick up MPH since that is where I picked up power. We'll have to see, its all bench racing right now because it will be at least 4 months before the track is open around here. I'm changing the induction around a bit this week and will be tweaking on it over the winter, but I'm still not sure where to midrange is. I don't have all my OBD2 tuning software here yet, but once I do, I'll start on the computer and see what I can figure out. The car is a hardtop WS6 6spd with AC and rear seats removed.
Dwayne, I hope I do too...
Old Mar 2, 2007 | 11:20 AM
  #83
FASTFATBOY's Avatar
I know I am digging one up from the dead, but I saw you car at Thunder when we were dropping off a friend of mines SS convertable.
I fell in love with your car, I wanted one like yours when I bought my 94 Z and could not find one..one slick ride I must say...I even took pics of it when I was there but it had the LT4 setup on it. The A/C, power steering, alternator deal was nice!
Can you post some pics of the hood and cowl area? How tall is the elbow on the car? Did it fit under a stock WS6 hood? Can you post pics with the hood shut?
David
Old Mar 2, 2007 | 04:42 PM
  #84
Turbo6's Avatar
David,
Thanks for the compliments. Here are a few pics in various iterations and requested photos.
BTW, if you are interested or know someone who is, I'm looking at selling it this spring.
Old Mar 3, 2007 | 09:55 AM
  #85
Z-RATED94's Avatar
Selling it, why?
Old Mar 3, 2007 | 11:09 AM
  #86
T/A lt1's Avatar
Awesome looking car I have to admit. Do you still have those Pontiac valve covers and would they clear shaftmount rockers? Thanks Clint
Old Mar 3, 2007 | 02:03 PM
  #87
Turbo6's Avatar
I'm looking to get more into road racing and would like something that I could race in the Silver State Challenge and One Lap of America.
I switched from the polished valvecovers to the Pontiac valvecovers so that it would clear my T&D shaftmounts.
KYWes
May 22, 2015 08:48 PM
C6LS3
Apr 15, 2015 09:50 AM
Elcojoe
Nov 17, 2014 10:27 PM
madman69
Aug 18, 2002 03:58 PM
