Simple Cooling Question
Old Apr 12, 2008 | 02:14 AM
ascastil's Avatar
What Is The Normal Operating Temp For A 97 Z28. Mine Seems To Bounce Back And Forth Between 180(the First Mark Above 160 On Temp Gauge?) And 210. Does Anybodys Temp. Do This Also. The Thermostat Opens, Fans Turn On If This Helps.
Old Apr 12, 2008 | 05:54 AM
Guest47904's Avatar
Guest
Spec says operating temps from 185 to 220. I advise getting a lower temp automatic fan switch to cut at least the primary on earlier.
Old Apr 12, 2008 | 08:09 AM
For stop and go operation, that would be completely normal.
BTW, take off your caps lock.
Old Apr 12, 2008 | 08:27 AM
2000GTP's Avatar
A PCM tune can adjust your fan on/off temps as well. With the stock thermostat and tuning, my car runs around 185 or lower all the time, never sees above that.
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
