Simple AFR "Eliminator" Cylinder Head Question.
Old Feb 20, 2013 | 12:50 PM
97 6SPEED Z's Avatar
Question Simple AFR "Eliminator" Cylinder Head Question.
I am considering buying a set of used AFR 210 "Eliminator" cylinder heads.
Problem is, the person I'm buying these used heads from, says he bought them, (directly from AFR) ....... in either May or June of 2007.
Could these heads still be the older style AFR 210's and NOT the "Eliminator" series AFR 210 heads???
When did AFR discontinue their older 210's, and replace them with the "Eliminator Series" heads ??????
Old Feb 20, 2013 | 11:05 PM
KW Baraka's Avatar
Re: Simple AFR "Eliminator" Cylinder Head Question.
You could try calling AFR.....but IIRC, the Eliminator name started being used more recently than 2007.
KW
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Elcojoe
Nov 17, 2014 10:27 PM
