Side mount wire looms for LTCC
Old Feb 5, 2007 | 06:41 PM
BMAN'S SCZ's Avatar
Hey guys I run a LTCC setup with the MBA covers for the coils. I was looking for a set of side mount (Head)wire looms like the ones Thunder racing sells. But I only want the metal mounts not the whole kit. Does anyone know were I can find these? The link below is what I am looking for. Thanks..........John
http://www.thunderracing.com/catalog...id=104&sid=385
Old Feb 6, 2007 | 04:14 AM
blown383's Avatar
The cheapest place I found there was there:
http://www.srbymichael.com/manufactu...ou/looms.shtml
They had pretty quick shipping. I used these same brackets when I went with the Canton valve covers.
-B
Old Feb 6, 2007 | 06:23 PM
BMAN'S SCZ's Avatar
I'll check it out Thanks........
Old Feb 6, 2007 | 11:02 PM
thesoundandthefury's Avatar
I'm actually kind've surprised that with the number of guys running OTVC wire setups that this hadn't caught on sooner, but here's another alternative to the "side mount" wire looms:
Same Made For You brackets, just with old skool Billet Specialties wire looms custom chromed. At first I thought I was going to have to drill holes in different locations in the billet looms to match up with the distance that the brackets were spaced but surprisingly the holes lined up perfectly out of the box. The only thing you may want to consider if you go this route is to get a tall set of valve covers to go with them: as you can see from the pics, the brackets make the looms sit about 1/2" higher than the stock valve covers.
Just out of curiosity, where do you have your coils mounted?
Old Feb 6, 2007 | 11:30 PM
95LT1conv's Avatar
^^^ where did u get those looms?
Old Feb 6, 2007 | 11:33 PM
http://www.billetspecialties.com/ite...id=144&pid=220
Old Feb 7, 2007 | 05:04 AM
blown383's Avatar
Holy crap.... is that head just polished on the outside or did you get it chromed also?!?>!
-B
Old Feb 7, 2007 | 08:23 AM
-B
Just polished.
Old Feb 7, 2007 | 03:06 PM
David @ Thunder's Avatar
The side mount brackets can be purchased seperately. It's listed under spark plug wire accessories.
116-82494 Made-For-You Center-bolt Aluminum Brackets (For use with vertical mount wire looms) $20.95
Old Feb 7, 2007 | 05:50 PM
BMAN'S SCZ's Avatar
Thanks again guys.........I will picking some of these up shortly.
Old Feb 7, 2007 | 06:07 PM
BMAN'S SCZ's Avatar
Are they polished like in your wire kit, and do they come with the seperators also. Thanks...........John
Old Feb 7, 2007 | 06:24 PM
They are just a standard satin finish but could be polished. No seperators, just brackets only with the part number I listed. I understood you didn't need the holders, but if you do, they are in the same section listed as vertical holders.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
