Sick motor!!!!!
Old Sep 15, 2004 | 12:18 AM
got8?'s Avatar
Sick motor!!!!!
Ok today i was putting in the sea foam in my car through the booster hose and it coughed up some black smoke, and it did it even befor that i was putting a water pump on the car and it would cough up smoke and no one seems to know whats going on. Any advice would be greatly appreciated.
Thanks!
Old Sep 15, 2004 | 04:50 AM
slopokrodrigez's Avatar
Re: Sick motor!!!!!
Black smoke is indicative of burning too much fuel. Could be a few reasons for that. Maybe a hole in the FPR diaphragm and fuel is leaking into the intake. Check the vac line on the regulator to see if it's wet. Could be a leaky injector. Could have a cylinder not firing. That's bad and could damage the cylinder. Check for that by using an infrared thermometer on the exhaust manifold. Or pull 1 plug wire at a time and see what happens to the engine. Or use a spray bottle of water. Also smell the oil on the dipstick and see if it smells like gas. Be sure to find out if you have a dead cylinder right away.
As far as Seafoam goes, it is an amazing product. It cleans the carbon out of our small engines in short order. HOWEVER, noone has said it won't harm O2's or catalytic convertors. Notice this page from Seafoam DOES NOT mention automobiles with gas engines????? http://www.seafoamsales.com/motorTuneUpTech.htm
I don't believe it is safe for the emissions systems on cars.
My personal feeling is, you could use it as often as you like if you remove the O2's and disconnect the cat(s). Therefore, you could only run it through the intake and not put it in the fuel. But I may be wrong.
Oh yeah, one more thing. Just attended a class put on by Standard auto parts. That's the MFR of sensors in the little blue box that makes several other brands of parts that are relabled. Bosch is one of them. The guru there told us 2 stupid things that everyone does (myself included) is put a K&N type filter on and remove the screen in the MAF. The screen cuts down on air turbulence so the MAF can more accurately measure the air stream and the oil from the cotton filter contaminates the MAF quite easily.
You may want to clean your MAF with brake cleaner when it's cooled off and the engine is off.
Just my .02
Dave
Old Sep 15, 2004 | 09:03 AM
got8?'s Avatar
Re: Sick motor!!!!!
Wow thanks for the help i will check that right away im changing my plugs and wires on friday anyway so i can be sure to check that too.
alex5366
Mar 27, 2015 03:30 PM
transam_388
Mar 15, 2015 11:53 AM
Roadie
Feb 16, 2015 10:34 AM
RiverMutant96
Jan 30, 2015 09:21 AM
