Should I use thread sealant on the coolant crossover pipe?
Old Jul 3, 2007 | 06:53 PM
kgkern01's Avatar
Getting ready to put a new coolant crossover pipe on my new set of heads and just wondering if I should use any permatex thread sealant on the bolts, or just bolt them on with the supplied gaskets only?
Old Jul 3, 2007 | 06:58 PM
mdacton's Avatar
You should only need the gaskets......any silicone or anything may smash out and clog up the pipe.
Old Jul 3, 2007 | 07:01 PM
wrd1972's Avatar
I used a tiny bit.
Old Jul 3, 2007 | 07:07 PM
SS RRR's Avatar
Agreed. No need. I use 4 seals instead of what looks like only two are called for in the Camaro parts manual.
When I used two I could smell coolant after the car got to temp. After using four it was no longer a problem.
Besides using sealant would do you no good. Since it is a banjo bolt coolant is channeld through the bolt past the threads.
Old Jul 3, 2007 | 07:29 PM
aboatguy's Avatar
When you say 4 seals do you mean one on either side of the steam tube (2 per banjo bolt 4 total?) If so thats correct!
I use a little antiseize on the banjo bolt threads.
Old Jul 3, 2007 | 07:49 PM
SS RRR's Avatar
Yep. However in the parts manual it only shows one per bolt.
Old Jul 3, 2007 | 07:52 PM
mdacton's Avatar
I always use the 2 per side also...........works like a charm
Old Jul 3, 2007 | 08:01 PM
Hmmm...my parts manual clearly shows 4 total seals in the 93-94 detail, but two shown in the diagram for 95-97. However both list 4 required when you read the part listing.
Old Jul 3, 2007 | 08:10 PM
SS RRR's Avatar
I have a bad habit of only looking at pretty pictures.
Old Jul 3, 2007 | 09:02 PM
kgkern01's Avatar
So no need for any sealant, just bolt on with the 4 supplied gaskets and I'm good to go, right?
Old Jul 3, 2007 | 09:17 PM
aboatguy's Avatar
Yep, with 1 gasket on each side of the steampipe (four total)
IE left side one between cylinder head and steam pipe and the other between steam pipe and banjo bolt head)
I know.....
but obviously someone has gotten it wrong!
Old Jul 4, 2007 | 11:29 AM
KPZ-28's Avatar
So, I should put anti-sieze on the banjo bolts? Mine came off easy and I want to keep it that way. Also- where is a good place to buy just the seals, my bolts look fine.
Old Jul 4, 2007 | 12:43 PM
96ZCamaro's Avatar
There are 4 seals needed. If you get them at the stealership they are about 8$ a piece I beleive. But the seals are the same thing as the seals on some a/c systems. Take in your old seals to a local autoparts store that knows what they are doing and they should beable to find the exact same seal for you for about a little less then 2$ a piece.
Old Jul 16, 2007 | 09:01 PM
9T7 Trans Am's Avatar
Anyone know the part number by chance?
*Edit, I found it: 10108689
Queens94z28
Mar 23, 2015 08:06 AM
cmsmith
Mar 16, 2015 02:34 PM
Omega9
Aug 2, 2002 12:33 AM
