should i get an electric WP?
Old Nov 30, 2005 | 11:40 PM
  #16
3gc's Avatar
3gc
Re: should i get an electric WP?
I'm fairly certain you can just throw the electric water pump in there. I remember the pump being a solid housing. Don't quote me on that though.
I went with the painless wiring kit. It comes with a circuit breaker and relay setup. Install was fairly easy. I didn't follow the wiring diagram painless provided and hooked it up so it would go on whenever the computer is telling the fuel pump to turn on. I went a little crazy and crimped as well as soldered all connections just for the extra security. It's been installed for about 1k miles now, no problems so far (knock on wood).
http://3gc.net/misc/water-pumpwiring.jpg
Old Dec 1, 2005 | 12:37 AM
  #17
plan Z's Avatar
Originally Posted by CHELOZ28
I thought If your water pump was leaking you had to replace the whole housing, someone please correct me if im wrong. My waterpump is leaking from that hole above the opti. To fix this would I just need a Mezeire water pump?
if you go with an electric pump, it will come with a freeze plug to put in the backside of the waterpump where the bearing/shaft used to go and that elinates the possibility of any water coming out of the weep hole on the bottom of the water pump housing.
Old Dec 1, 2005 | 02:14 PM
  #18
CHELOZ28's Avatar
sweet thanks guys
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
