should brand new lt1 hydraulic lifters be hard to compress?
Old Jun 18, 2010 | 09:58 PM
z28beast's Avatar
ok so i bought some new comp cams lifter from summit and the plunger wont compress at all...i tried to compress it with a pushrod and i couldn't....i called tech and they said after they soak in oil it will compress...is this true or should i and have them exchanged?
Old Jun 19, 2010 | 07:50 AM
Stl94LT1's Avatar
I would send them back and get the LS7 lifters.
Old Jun 19, 2010 | 10:05 AM
wrd1972's Avatar
Usually, lifters without oil will compress a little. Agreed on getting the LS7 lifters.
Old Jun 19, 2010 | 10:30 AM
retromek's Avatar
So, not hi-jack this thread but will the LS-7's just drop in like the lt1 lifters?
I'm changing mine out as well and all the negativity on the comp's makin' look for the GMPP's which are damn near impossible to find
thanks
chris
Old Jun 19, 2010 | 11:23 AM
MachinistOne's Avatar
the lifter is pumped up, use a bench vise and a bolt to slowly compress it and drain the oil out. Be careful and don't try to go past the bottom out point.
Old Jun 19, 2010 | 11:38 AM
z28beast's Avatar
well its not only 1 lifter...its all 16 of them..... i cant compress any of them....and machinist would you reccomend the ls7 lifters also? i really dont wanna switch because i have laready checked my pr lenght and ordered custom hardened pushrods
Old Jun 19, 2010 | 11:39 AM
Stl94LT1's Avatar
thanks
chris
GMPP
http://www.summitracing.com/search/?...12371042&dds=1
LS Series
http://www.summitracing.com/search/?...12499225&dds=1
HectorM52
Jul 30, 2017 11:46 AM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
siguy
Nov 27, 2014 10:07 AM
