Should be in the 12's, right??
Old Feb 14, 2003 | 12:02 PM
ZyberMunster's Avatar
94Z A4 OEM weight.
LT4 kit, Vigilante converter, MAC's, 3.73's, MSD, PCMForless, MAC torque arm, Lakewood control arms, SLP sfc's, SLP CAI, gutted cat, SpinTech muffler.
NO SPRAY!!
Laterzzz...
Old Feb 14, 2003 | 12:05 PM
teke184's Avatar
yeah with traction...
Old Feb 14, 2003 | 12:10 PM
Eddie95Z28's Avatar
Yeah you should be good in the 12's I have a 95 Z with no weight reduction CC305 stock convertor and 3.23 gears and I bipped the 12's
Old Feb 14, 2003 | 12:13 PM
Mmmm...
Almost forgot how "addictive" this is!!!
12's here we come...
Laterzzz...
Old Feb 14, 2003 | 01:21 PM
Javier97Z28's Avatar
Moderator
you better be i hit 12's w/o the cam... planning on low 12's w/ the cam
u better put a good tire on it tho, b/c if not all you'll be seeing is 13's w/ high MPH
Old Feb 14, 2003 | 01:27 PM
mmmm....sweeet!!!
i have some salad shooters and some 17x11 ZR1's, suggestions on tire choice, salad's would be on for track only...
Old Feb 14, 2003 | 01:54 PM
Moderator
Originally posted by ZyberMunster
mmmm....sweeet!!!
well I hear the track prep at Moroso is getting a little better, i guess it all depends on how serious you want to get...
when I get a cam and I finish up my nitto's i'm stepping up to ET Streets on my salad shooters.. right now I have salad shooters w/ nitto's and they work OK as long as the track is prepped nicely.. I can cut 1.8's at Moroso, and 1.7's at a real track like Bradenton.
Old Feb 14, 2003 | 05:16 PM
BOWTYDE's Avatar
So that means that my LT1 should be hitting 12s with its new set up?
Old Feb 15, 2003 | 12:05 AM
Smokn '94 Z's Avatar
Thumbs up Re: Should be in the 12's, right??
94Z A4 OEM weight.
NO SPRAY!!
Laterzzz...
Check my sig. Your car is very similar to mine... 12's should be no problem...
Old Feb 15, 2003 | 03:33 AM
VINCELEE123's Avatar
need headers
you should make it in the 12s no problem if you hook, 0
but all that work with out headers? macs are cheap and will help plenty.
vince
