Shop tightened oil filter too much, screwdriver method no go, HELP!!!
Old Dec 8, 2006 | 07:12 PM
zbomb5610's Avatar
So when i attempted to get my second rebuild done that resulted in failure, i figured i would change the oil on my car for the drive home so i could do my 3rd and final rebuild and do it right.
Well the filter was on way too tight, some MIGHTY branded one or some ****, hella short filter, no room to get to it.
I tried taking it off with my hands, then one of the rubber circle grip things, tried this other tool with teeth but it wouldn't go around the filter.
Then i tried the screwdriver method and all it did was RIP APART the oil filter.
Now i have this oil filter that is all damaged with a few big holes in it and at the bottom.
WHAT CAN I DO, WHAT SUGGESTIONS ARE THERE????
thanks
Z
Old Dec 8, 2006 | 07:29 PM
lt1srule's Avatar
wrap a leather belt around it. wrap it like 3 times nice and tight and pull with both hands works if done. right..
Old Dec 8, 2006 | 07:46 PM
Sweetred95ta's Avatar
Craftsman Strap Wrench.
http://www.kmart.com/catalog/product...10000000&Nty=1
Old Dec 8, 2006 | 09:06 PM
grammerman's Avatar
A very LARGE pair of channel locks reaching straight up front the bottom and gripping the sides usually works.
Old Dec 8, 2006 | 09:32 PM
SS RRR's Avatar
indeed
Old Dec 8, 2006 | 09:54 PM
gex598's Avatar
Did you put the screw driver all the way thur the middle? If it doesnt come out the other side it usually wont work.
Old Dec 8, 2006 | 09:58 PM
v8pwrdz28's Avatar
i use this method at work, it rules. also nice to use the filter socket things we have, they come in handy.
Old Dec 9, 2006 | 04:29 AM
Heatmaker's Avatar
Advanced Member
You have to use a very large screw driver about 1 foot long, and poke it all the way through the other side, then twist and twist... the metal should start to twist till it eventually is twisted so much that it can't tist anymore, then keep turning till it unscrews... worked for me.
Old Dec 9, 2006 | 03:10 PM
zbomb5610's Avatar
thanks for the help guys, but i started another thread since i am in a whole new situation with this problem.
I tried a few things, a few things just wouldn't work, but i am s.o.l. at the current moment.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
