Shoebox, need two part numbers.
Old May 9, 2004 | 05:32 PM
Loadre's Avatar
1994 Z28
EVAP Canister Purge Solenoid Valve located on pass side of intake manifold.
The other sensor was located in the square block that houses my oil filter. It had a flexible covering that went over it. It was black and about 3 inches long, until my buddy decided to try and lift the engine by grabbing onto it.
Old May 9, 2004 | 10:22 PM
EVAP
Is the other thing you are describing the oil pressure sensor? 1st design 1994s got them on the side of the block like the 1993s did.
24575127 if that is what it is.
Old May 10, 2004 | 05:55 AM
Loadre's Avatar
<bows> Thank you.
novaiiman
May 15, 2016 11:36 AM
NewsBot
Jan 29, 2015 07:10 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
