Shoebox? Code 29 AIR Pump Problem Still....
Old Jun 16, 2004 | 03:01 AM
chesee48's Avatar
I changed the fuse and unpluged the harness and for a while the SES light went off. Then one day when it was wet out, the SES light went back on. I replaced the fuse and unpluged it again and it didnt go away.
I know u said 9/10 times its the fuse, but whats the 1/10? That the AIR PUMP needs to be changed?
The only thing that i wanted to add that when i did replace the fuse the first time, i noticed that the fuse in there was a 25amp opposed to the 20 that was suppose to be in there. I nver touched it tho before and ive had the car for 5 yrs..
Old Jun 16, 2004 | 07:52 AM
Maybe there is some crud or corrosion in the connector you unplugged. Try cleaning it out.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
