shimming valve springs for basic cam swap
Old Mar 7, 2007 | 03:20 PM
69z-28's Avatar
im having trouble figuring out what needs to be done for this. im debating buying the parts individually or the crane kit,however i have stock heads and dont wanna take them to a machine shop to see what the spring height should be set to. can anyone tell me the simplest way to get springs retainers and locks installed without screwing around with micrometers or calipers or something to get the shims set perfectly. this is a DD so im not looking for optimum HP. just a weekend cam swap in my garage for a little more fun.
BTW, the machinist i talked to today said not to use any shims at all so i dont put too much pressure on them. what you guys think about options i should take.... i need to know what springs, retainers and locks to buy along with shims, if any at all.
Old Mar 7, 2007 | 03:23 PM
mdacton's Avatar
what cam is it?
You need to know that first....I don't know the stock installed height...1.78"?
Talk to someone that knows valvetrains and they can lead you in the right direction after you pick the cam
Old Mar 7, 2007 | 07:39 PM
69z-28's Avatar
will most likely be the comp 503. with the crane 10308 kit i beleive it is. stock heads and 1.6 SA 3/8 rockers.
Old Mar 7, 2007 | 07:42 PM
mdacton's Avatar
well I'm not familiar with that kit...you probly wont need to shim it tho if its a kit
Old Mar 7, 2007 | 07:43 PM
speed_demon24's Avatar
I'de be carefull with those crane springs, I think they are the reason my gm846 started coming apart on a lobe, I had close to 160lbs of seat pressure on them.
Old Mar 7, 2007 | 09:43 PM
69z-28's Avatar
wtf, ive heard tons of people have good luck with them.lol
Old Mar 7, 2007 | 10:49 PM
Well at 1.85" they have 130 lbs on the seat and chances are you won't have them at 1.85".
Old Mar 7, 2007 | 10:51 PM
69z-28's Avatar
would not using the shims with them be a better idea?
Old Mar 7, 2007 | 10:52 PM
Then the springs would eat right through the heads, make sure you check the installed height with them, dont just bolt them up and hope they are ok.
Old Mar 7, 2007 | 11:00 PM
Pyrodawg's Avatar
i have the crane kit on my car, everything that came with it is on there
Old Mar 7, 2007 | 11:29 PM
seawolf06's Avatar
Originally Posted by NightTrain66
yep, these work fine with no machine work and can handle a pretty big cam.
I now use these on my LE1 heads instead of the CM 612 springs.
Some thick alu rockers sometimes have problems with the large diameter retainer but Comp Pro mags work fine.
Get that kit and you should be fine. The "shims" you're talking about are called locators and come with the kit.
Old Mar 7, 2007 | 11:38 PM
Nope they are shims, thats part of the reason why the kit is so cheap. Some people use the comp hardware with the crane springs, thats what I did atleast. I'm running 918's right now though...
Old Mar 7, 2007 | 11:40 PM
seawolf06's Avatar
Oh, that uses the stock locators? New to me.
Old Mar 8, 2007 | 12:04 AM
69z-28's Avatar
hmmmm. so theres the head, the "locator" is this the same as a shim? then the spring, retainer and locks obviously right?
can anyone else verify that the kit is a drop in/ bolt in kit with the 503?
Old Mar 8, 2007 | 12:20 AM
No, they simply use shims, flat shims, not seats or locators.
oldschool
Feb 9, 2016 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
