Shifting and speedo problem HELP stumped
Old Mar 3, 2012 | 06:43 AM
Blackphantom's Avatar
So i just picked up a 93 z auto drove good when i was test driving. Went to drive it the other day start the car and the speedo just starts going crazy it started reading 60-70mph with the car at idle. i put the car in drive and the speedo reads correct when im driving. that problem 1
Problem 2- kinda hard to explain the car will run awesome quick and fast but the tranny doesnt like to shift.. and when the tranny shifts nice and easy and i give it full throttle the car boogs stumbles runs like ****.
IDK what these problems could be i was thinking VSS but thats not the case any ideas??
Old Mar 3, 2012 | 07:09 AM
Re: Shifting and speedo problem HELP stumped
just noticed that at idle if i put my foot on the brake the speedo goes down take foot off brake speedo goes up wtf
Old Mar 3, 2012 | 09:52 AM
my1994z28's Avatar
The speedpometer problem sounds like a bad ground wire somewhere,I would check the connector or sensor on the trans..If the trans is slipping when you jump on it,sounds like time for a rebuild.
blac94Z
Feb 10, 2015 11:02 AM
Jessie4tin
Jan 7, 2015 08:53 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
