Shift light installation
Old Oct 17, 2003 | 09:51 AM
IslandZ's Avatar
Can anyone point me to an instalation page for the AutoMeter Quick-Lite Shift Lite. I tried searching but couldn't find it for the LT1 only LS1.
Thanks!
Old Oct 17, 2003 | 08:09 PM
Bud M's Avatar
Didn't it come with instructions?
You should have 3 wires. One for 12v switched, one for ground and one for tach. I went under the dash and found 12v switched using the schematic in my manual, used the body for ground and ran the tach wire to the coil. You can also use a tach wire at the PCM.
As far as mounting it you're on your own. I placed mine at the base of the A pillar using that plastic heavy duty velcro-type stuff made by 3M. You can get it at the supermarket and it work great.
Jason Short
Jan 19, 2015 06:34 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
